查看: 921|回复: 3
60E3F扩容32G升不了级
QQ
发表于 2026-5-19 14:31:29 | 显示全部楼层 |阅读模式
在这里购买了60E3F(0000)扩容数据,自动识别EMMC大小的这个数据,原机8G内存,我更换32G内存后,用购买的软件无法升级?怎么处理?
QQ
 楼主| 发表于 2026-5-19 15:12:24 | 显示全部楼层
打印信息如下
MDrv_PNL_Init g_ptr_XCExtendRiuBaseAddr = 1F600000
[do_create_osdlayer] GOP Boot Logo Index 1
create instance at 28804838 with private size 1732 bytes at 28804888
[Utopia][GE HAL]: [GE_Init][942]VCmdQSize = 0xtx < GE_VCMDQ_SIZE_MIN = 0xtx
create instance at 28804F50 with private size 10112 bytes at 28804FA0
create instance at 28807728 with private size 1928 bytes at 28807778
[MApi_XC_GetMirrorModeTypeEx, 1686]No instance existed, please get an instance by calling MApi_XC_Init() first
[MApi_XC_GetStatus,12688]No instance existed, please get an instance by calling MApi_XC_Init() first
** Partition 0 [NEC] u16IRKeycode = 43 u8RepeatFlag = 0
not valid on device 0 **
** Unable to use usb 0:0 for fatload **
reading /TargetHis/His668Upgrade.bin
[NEC] u16IRKeycode = 43 u8RepeatFlag = 1
1 bytes read
16384 bytes read
-1584885728 bytes read
[HIS][UB]cmd=filepartload 2882A0B0 /TargetHis/His668Upgrade.bin 0 F0
[HIS][UB]cmd line size exceed 128
[ERROR] LoadScript2DramByUsb:833: Error: check_script_crc Fail !!
MBoot will reset within 10s, if you don't want to reset, please run wdt_enable 0!!
jump_to_console start!!
<< M7332 >># [NEC] u16IRKeycode = 43 u8RepeatFlag = 0
UART_115200
AC_ON
00-2L-SM-02-20190530
MIU0_DQS-OK
BIST0-OK
*optee teeloader entry
CusConfig
eMMC_RPMB_Check_Program_Key
*ree_opt=00000023
Auth reeloader...
Decrypt reeloader...
Version check on reeloader...
reeloader_addr=20100000
NOTICE:  BL3-1: v1.1(debug):
NOTICE:  BL3-1: Built : 23:56:10, Apr  9 2020
INFO:    warmboot return address : 7dd01c00
INFO:    BL3-1: Initializing runtime services
NOTICE:  From args : boot_mbx = 2002808c
INFO:     [Booting] mstar_send_magic_ATF 479
INFO:    BL3-1: Initializing BL3-2
[Ramlog] ramlog_init init success
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x20100000
INFO:    BL3-1: Next image spsr = 0x1d3
INFO:    BIN1_32bit mode Apr  9 2020 23:56:08
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
ree_entry
         U
Relocation Offset is: 01A00000
hs>>power-on
[AT][MB][start ub][565]
U-Boot 2011.06-00021-g45c54cd-dirty (May 16 2020 - 18:47:13)
[Mboot] ===== sw IR Config Register =====
[Mboot] ===== Attach IR Interrupt  ======
[Utopia][SYS]: Function = SYSOpen, Line = 3402, current resource pri_shm content is: 0
[Utopia][SYS]: Function = SYSOpen, Line = 3421, [SYS INFO] OPEN INSTANCE...
create instance at 287F3A50 with private size 108 bytes at 287F3AA0
[Utopia][MIU]: [MIU INFO] miu opencreate instance at 287F3B10 with private size 168 bytes at 287F3B60
create instance at 287F3C10 with private size 60 bytes at 287F3C60
uboot held at [285DDF60~29800000],size=012220A0
Uboot Relocation:  152 MiB
Now running in RAM - U-Boot at: 28E00000
eMMC: HS400 5.1 200MHz
eMMC 29.12 GB
CID:0x00A98428
0xABD20032
0x33305032
0x5900019B
[HIS][UB]eMMC SLC mmc type 0%-10% device life time used
[HIS][UB]eMMC MLC mmc type 0%-10% device life time used
[HIS][UB]eMMC pre_eol_info normal
DRAM : 1536MB
SAR5=ON
Net:   No ethernet found.
no eeprom
0x18 0x30 0xC 0x97 0xD 0xDD
MACaddr = 0x180x300xC0x970xD0xDD
the same ethaddr!
MAC:  0x18: 0x30: 0xC: 0x97:0xD: 0xDD
create instance at 288040D8 with private size 44 bytes at 28804128
[AT][MBoot][Driver Init][684]
Hit ~ to stop autoboot:  0
In:    serial
Out:   serial
Err:   serial
[HIS][UB]LEDcontrolType=1
[HIS][UB][AT][MB][do_HisColorLEDControl][697]
[HIS][UB]IIC colorLED  cotrol--LED breath FAIL!!
[HIS][UB]Judge Raw EMMC
[HIS][UB]Not Raw eMMC
[HIS][UB][Onebin]ProjectId               120
[HIS][UB][Onebin]ProjectIdBack           120
[HIS][UB][Onebin]Same ID, don't need load datasepara
mmc change mount : tvconfig
** File not found model.info
[ERROR] vfs_getsize:420: ext4filesize mmc fail, try again!
[ERROR] vfs_getsize:424: ext4filesize mmc fail
No enough buffer or path fail(model.info) :
[src/MsUtility.c] [loadscript]
model.info not find !! Clean model_info env
Writing to MMC(0)... 128 blocks written: OK
done
0:MCP_X_D3_2133_8G_4x
1:MCP_X_D3_2133_4G_4x
DRAM Channel 0 Size = [2048MB]
Changelist:     24543697
============= set bootargs ===============
[HIS][UB]CS602 IC, need write every time!!!
done
[HIS][UB]TCON_2in1_ADDR: 266
Hit Enter to stop autoboot:  0
enable dont overwrite function
[HIS][UB]ToFacMode is M
done
Boot Check: Reboot by WDT --------
hisense>>AC on
[HIS][UB]Not in Factory Mode
[Mboot_IR] boot from dynamic ir
fore uup u8KeyPad_KeyVal [0xFF]
BootMode update by force_upgrade
Boot Check: BootMode = 4 --------
Upgrade Version: 1.0
done
done
Check USB port[0]:
[USB] usb_lowlevel_init++
[USB] USB EHCI LIB VER: 2014.10.02
[USB] Port 0 is Enabled
[USB] TV_usb_init (UTMI Init) ++
[USB] UTMI Base 1F207500
[USB] UHC Base 1F204800
[USB] USBC Base 1F200E00
[USB] BC Base 1F246C00
[USB] config miu select [F0] [EF] [EF] ][EF]
[USB] enable miu lower bound address subtraction
[USB] init squelch level 0xE
[USB] TV_usb_init--
[USB] Usb_host_Init++
[USB] Async base addr: 0x97CDD80
[USB] Reg 0x28: 0xDD80 0x97C
[USB] disable run
[USB] Host Speed:2
[USB] enable aynch
[USB] Usb_host_Init--
[USB] usb_lowlevel_init--
scanning bus for devices... New Device 0
[USB] control1 max:40
[USB] interface[0] conf:1 value 8:
1 USB Device(s) found
       scanning bus for storage devices... [USB] no_of_ep: 2
[USB] find bulk ep: 0
[USB] find bulk ep2: 1
[USB] bulk max packet size: ep(in) 0x200, ep2(out) 0x200
[USB] bulk0 is in
max lun:0
1 Storage Device(s) found
Search_tvdatabase
** Find tvdatabase **
mmc change mount : tvdatabase
Size of file "/readme" from mmc device 0 partition tvdatabase: 51 bytes
find readme, do not upgrade tvdatabase
Current state ->[0x8]
create instance at 28804648 with private size 408 bytes at 28804698
MOD Output Channel Order not set!!!!
Active Standby Mode FALSE =====
MsDrv_PNL_Init:Bypass SetDivison
MDrv_PNL_Init u32PnlRiuBaseAddr = tx
MDrv_PNL_Init u32PMRiuBaseAddr = tx
LINK TYPE = EXT
[MHal_PNL_Init_MOD][4097]Vx1 2 division
[MHal_PNL_Init_MOD][4221]Vx1 2 division
[MApi_XC_MLG_GetStatus, 3037]No instance existed, please get an instance by calling MApi_XC_Init() first
->I-PWM init; ->V-PWM init begin!
init V_PWM_ENABLE = 1
force set safemodeset off
get backlight level form deviceinfo =40000
init I_PWM_ENABLE = 1
->I-PWM init; ->V-PWM init end!
[msReadEfuse][3384]u32Result=tx, after mask u32Result=tx
EN_DEMURA_MULTI_NOT OK
[ERROR] MApi_Demura_Init:296: multi_vendor input is not valid, init fail
[AT][MB][panel_pre_init][2425]
Wait for PM51 standby DRAM ...........PM51 run ok...........NO PanelOnTiming3 Delay ....
---MsDrv_PNL_BackLigth_On:1558 Set MsDrv_PNL_BackLigth_On DelayTask 1182
** Partition 0 not valid on device 0 **
1 bytes read
16384 bytes read
<< M7332 >># UART_115200
QQ
 楼主| 发表于 2026-5-19 15:45:15 | 显示全部楼层
用的32G长江储存,升不了级,换了海力士64G,还是升不了级,管理看到后麻烦回复一哈
发表于 2026-5-20 07:19:53 | 显示全部楼层
已发送私信,请注意查收
